Hey all, looking for some PC help. A few months ago my PC started to start and fail to boot 5-30 times whenever I try to turn it on.
The fans spin up and lights turn on for about 3 seconds then it all stops and tries again multiple times. Sometimes it does this 3-5 times and sometimes it's up to 30 times. Then finally it finishes the sequence and it posts.
Anyone have any idea what is causing this? All drivers are updated, I have restored to before the problem started, and ran hard disk checks.
I think it is something to do with motherboard, but I'm not sure. Want to get more info before I buy a new mobo, processor, and ram.
Any help would be greatly appreciated.
i7 4790K not overclocked ATM, Gigabyte Z97 Gaming 5, EVGA GTX970, 16G Ripjaws, Windows 10 Home Version 10.0.16299 Build 16299
https://linustechtips.com/topic/882273-pc-startup-issue/
Sounds like this might be a memory issue. Have you tried underclocking your memory and checking to see if the issue still occurs?
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/882273-pc-startup-issue/#findComment-10903234
@timmay7111 or trying one stick at a time, switching between all the MOBO RAM slots, seeing in which slot it does posts? (doing the same with the other stick)
*I'm guessing you have 2x8GB sticks, since you didn't point out you have 1x16GB
https://linustechtips.com/topic/882273-pc-startup-issue/#findComment-10903273
  • 4 weeks later...
Bumping thread. I tried changing the ram out/ using different slots but it didn't fix the issue.
Anyone have any other troubleshooting ideas or know what could cause this issue?
Really don't want to buy a bunch of new components with the way prices are lately.
https://linustechtips.com/topic/882273-pc-startup-issue/#findComment-11001731
Check your temps once you get it booted into windows again.
If your CPU fan isn't working properly or there's bad thermal transfer going on with your heatsink like if the paste is dried up or it's no contacting right, it will shut down while trying to boot like you're describing.
https://linustechtips.com/topic/882273-pc-startup-issue/#findComment-11003253
Make sure cpu and 24 pin cables are pushed enough in
https://linustechtips.com/topic/882273-pc-startup-issue/#findComment-11004225
