So this is my first pc build and I just finished today but when I went into the bios I saw my memory was running way below it’s stock speed. I bought G skill ripjaws V series 2x4gb ddr4 3200 memory, my motherboard is the gigabyte ga ab350 gaming 3 and it has a ryzen 5 1600. The memory was running at 2133 how do I get it up to the 3200 it’s suppose to be at?
https://linustechtips.com/topic/882261-memory-not-at-right-speed/
Unfortunately, your motherboard does not support memory clocked at 3200MHz at this time. Your motherboard will only support DDR4 modules up to 2667 MHz, but this may change in a future BIOS update. You can view compatible memory modules at http://download.gigabyte.us/FileList/Memory/mb_memory_ga-ab350-gaming3.pdf.
Make sure you're running the latest BIOS to get the latest in DDR support, which seems to be F10 at http://www.gigabyte.us/Motherboard/GA-AB350-Gaming-3-rev-10#support-dl. This may allow you to achieve a clock speed of 2667MHz.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
Are you sure? Because on pc part pickers and a couple other websites it says that 3200 is compatible to that mobo but I’ll do a bios update to see if that could fix it
-snip-
I may be wrong, as I'm purely going off your motherboard's manual and supported memory list.
If you're skeptical, I'd suggest that you try updating your BIOS and changing the memory frequency and timing settings under the M.I.T tab. See page 23 of your manual for details on these settings.
Desktop
Homelab
Checked it your right the max speed is 2667 but it goes up to 3200 once I update the bios to f10, I’m at f7 thanks my guy
