I just put a new motherboard and cpu in my pc and did a fresh install of windows but now windows 10 will not find a graphics card driver and the one it find in windows updates fails to install and when I download the driver from NVIDIA it fails to install too help!!!!
-My System-
Ryzen 5 1600X(@stock) | AMD Wraith Prism Cooler | 16gb Ballistix Sport Ddr4 (@2666mhz) | XFX GTS Black Edition RX 580 8gb |
Asus B450M-A Motherboard | 500gb 840 Evo Ssd | 550w evga N1 Power Supply | Vivo Micro Atx Case
-Peripherals-
Acer KG1 1920x1080p 75hz FreeSynce Monitor | Red Dragon M601 Mouse | Red Dragon K55 Keyboard |
Logitech G430 Headset | FiFine 669B Microphone | Logitech Z323 Speakers |
PcPartPicker Link
https://linustechtips.com/topic/881345-i-need-help/
5 minutes ago, VVord said:
Did you use Geforce Experience or download the driver directly?
Downloaded it directly
-My System-
-Peripherals-
PcPartPicker Link
https://linustechtips.com/topic/881345-i-need-help/#findComment-10894059
4 minutes ago, VVord said:
Use Geforce Experience. That worked for me when I had this issue.
I ill try that now
-My System-
-Peripherals-
PcPartPicker Link
https://linustechtips.com/topic/881345-i-need-help/#findComment-10894074
It did not work it still failed
-My System-
-Peripherals-
PcPartPicker Link
https://linustechtips.com/topic/881345-i-need-help/#findComment-10894092
Make sure you have windows 10 64 bit installed and that windows is up to date. Download display driver uninstaller. After that boot into safe mode and run DDU to clean the drivers. Then install the manual driver package again.
https://linustechtips.com/topic/881345-i-need-help/#findComment-10894119
All done but still no and I just looked and it’s not even recognized in windows
-My System-
-Peripherals-
PcPartPicker Link
https://linustechtips.com/topic/881345-i-need-help/#findComment-10894286
And you have the monitor connected to it? What card is it?
https://linustechtips.com/topic/881345-i-need-help/#findComment-10894288
Yes lol and it’s a gtx 770
-My System-
-Peripherals-
PcPartPicker Link
https://linustechtips.com/topic/881345-i-need-help/#findComment-10894293
Then it has to be reconsigned. So in device manager it shows generic display adapter?
https://linustechtips.com/topic/881345-i-need-help/#findComment-10894303
Yes but when I talked to Nvidia and sent them the system spec thing my cpu was not on there they said
-My System-
-Peripherals-
PcPartPicker Link
https://linustechtips.com/topic/881345-i-need-help/#findComment-10894351
CPU? if the monitor is connected to the graphics card its clearly fucking working no? The issue is the first driver install.
Try an older package maybe: https://www.geforce.com/drivers/results/126179
https://linustechtips.com/topic/881345-i-need-help/#findComment-10894387
