Hi,
so I am in need of an upgrade for my studio PC. I came up with this, what do you guys think of it? I am not that experienced so any help or optimizations are appreciated.
The main purpose will be audio recording/editing etc. All I need is a lot of CPU power to handle that load. I did not include storage or a gfx card as I will be using the same from my old PC.
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  (£349.95 @ Aria PC)
CPU Cooler: NZXT - Kraken X62 Rev 2 98.2 CFM Liquid CPU Cooler  (£125.95 @ Aria PC)
Motherboard: Asus - Prime Z370-A ATX LGA1151 Motherboard  (£155.47 @ Amazon UK)
Memory: Corsair - Vengeance LED 32GB (4 x 8GB) DDR4-2666 Memory  (£245.99 @ Ebuyer)
Case: Fractal Design - Define R6 Black TG ATX Mid Tower Case  (£129.84 @ CCL Computers)
Power Supply: Corsair - 750W 80+ Platinum Certified Fully-Modular ATX Power Supply  (£124.98 @ Amazon UK)
Total: £1132.18
Generated by PCPartPicker 2018-01-03 16:50 GMT+0000
Thank you!
https://linustechtips.com/topic/881135-audio-pc-build/
Get a Corsair H100i v2 instead of the Kraken X62.
I would hold off on the 750W PSU, you're not going to be drawing anywhere near that much power. Probably go for a 550-650W.
Other than that, all looks good.
https://linustechtips.com/topic/881135-audio-pc-build/#findComment-10891925
Thanks for the suggestions! Do you have any particular PSU recommendation? I am quite lost when it comes to them tbh.
https://linustechtips.com/topic/881135-audio-pc-build/#findComment-10891944
The Corsair CX550M is quite good.
https://linustechtips.com/topic/881135-audio-pc-build/#findComment-10891948
Here's a cheat sheet. Pick a tier 1-2 unit. The RMx is among the quietest PSUs.
https://linustechtips.com/topic/881135-audio-pc-build/#findComment-10891977
1 hour ago, 1llusion said:
Hi,
Total: £1132.18
Thank you!
Consider getting the i7-8700 with a cooler like the Noctua NH-12S or Cryorig H7. Performance very close to a stock i7-8700K but runs much cooler and therefore quieter.
PSU requirement depends a great deal on the gpu being used. Corsair CX450M (2015)SeaSonic FOCUS Plus 550 Gold, or SeaSonic FOCUS Plus 650 Gold are quiet and very good quality.
https://linustechtips.com/topic/881135-audio-pc-build/#findComment-10892316
