Hello folks,
I bought a seccondhand hp s5000 slimline desktop
with a core 2 quad: q8300
i booted the machine and did a factory reset. i noticed when i start a program or something it starts blowing violently.
so i opened hwmonitor and the cpu is touching 95 to a 100 quite fast
after instaling aida64 and starting a stresstest it imidiatly throteld to hell
when hwmonitor tells me the cpu is at 60 or 70 i can touch the heatsink and it is cold do i have a bad mount or somethng?
Thanks in advance
Greetings
snert98
Gaming rig) i5-4690k@3,5ghz,4,1ghz turbo , gigabyte z97x-gaming 3, hyperx fury red 2x4gb(1600mhz), msi GTX 970 gaming 4, corsair cs650m PSU, corsair carbide spec-03 case, be quiet pure rock Cpu cooler, kingston v300 120gb ssd, samsung evo 830 120gb ssd, segate baracuda 1,5tb hdd, Laptop 1) HP pavilion power, i7 7700hq, 16gb ddr4, 256gb nvme ssd, 1tb hdd, nvdia gtx 1050 Laptop 2(linux mint)Dell Xps 15(2011), i3-2130m, nvidia gt525m, 4gb 1333mhz ram, 500gb hdd Laptop3(mint and windows)Dell inspiron 15z(2013), i5-3337u, hd 4000 graphics, 6gb 1600mhz ddr3, 500gb hdd, 32gb ssd(RST) First PC(still using for some windows XP programs)Amd athlon xp 1500+@1,96ghz, 2gb 300mhz ram, PNY geforce 6200, 80gb maxtor hdd, asus(tek) a7n8x-deluxe , 450W psu, spire case
https://linustechtips.com/topic/880671-hp-s5000-overheating/
It could have a bad mount, or the TIM is bad. I would suggest reapplying the thermal compound and making sure the cooler is seated on the CPU correctly.
https://linustechtips.com/topic/880671-hp-s5000-overheating/#findComment-10887560
Thanks will take the cooler of tonight it is doing windows update atm let you know what happend
https://linustechtips.com/topic/880671-hp-s5000-overheating/#findComment-10887567
4 minutes ago, Damascus said:
Replace the thermal interface
i found an old tube of thermal paste, i does not have a use before date but how do i know i can still use it?
https://linustechtips.com/topic/880671-hp-s5000-overheating/#findComment-10887603
If it's separated don't use it (if it's very watery or super hard)
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/880671-hp-s5000-overheating/#findComment-10887684
took the cooler of as it turns out the thermal paste dryed but the cooler wasnt mounted tight cause two of the four corners the plastic was broken, trying to superglue it now maybe it wil be strong enough
https://linustechtips.com/topic/880671-hp-s5000-overheating/#findComment-10888092
