Alright so I have a ASUS M5A78L-M/USB3 DDR3 HDMI DVI USB 3.0 760G MicroATX Motherboard amd Fx 4300 not overclocked, and a 600watt power supply and a nvidia gtx 1050 ti 4gb Not overclocked AND I wanna upgrade to the ASUS M5A78L-M Plus/USB3 DDR3 HDMI DVI USB 3.0 760G MicroATX Motherboard and the AMD FD8350FRHKBOX FX-8350 FX-Series 8-Core Black Edition and I wanna know if 1. I'll have enough Power to support everything. And 2. Is the new one I'm getting is it better then my old one??? And apparently the coolermaster power supply calculator seem to think I'll have more then enough to support everything, Just posting again I didn't really get an answer last time I hope this is allowed.
https://linustechtips.com/topic/880485-need-help-and-infomation/
What PSU do you have?
Don't upgrade though.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
The answers to your questions are both yes. However, I would HIGHLY recommend going to Ryzen or waiting for Ryzen v2 rather than staying on the FX series. What exactly would you be planning on doing (or what do you do with your system)? Since you are already buying a new motherboard, I would definitely go to something like a B350 chipset and pair it with even a Ryzen 3, which will be leaps and bounds ahead of the FX 8350. And won't cost you a whole lot more.
