So I currently have a 1920 X 1200 monitor and my wallpaper is 2560 X 1440 (link: The Cosmo Knight) and I am upgrading to a ultrawide monitor by LG (LG 29UC88-B at 2560 X 1080) but I have tested my wallpaper on the monitor and it seems to have a bit of the top and bottom cut off. So I am asking, how would I make it so it looks normal.
Or would you recommend any other wallpapers like this one to fit my ultrawide.
Thanks
Specs:
Motherboard: Gigabyte Z97X Gaming 3
CPU: Intel Core I7 4790K
GPU: Gigabyte G1 Gaming GTX 970
RAM: HyperX Fury 16GB
HDD: Seagate ST3000DM001 3TB
SSD: KINGSTON SV300S37A480G 450GB
Cooler: Corsair H100i GTX
Case: NZXT H440 Red
Monitor: DELL U2412M
Keyboard: Gigabyte Force K7
Mouse: Corsair Sabre RGB
https://linustechtips.com/topic/879633-wallpaper-conversion/
How would you do that without it looking all stretched?
Specs:
Case: NZXT H440 Red
https://linustechtips.com/topic/879633-wallpaper-conversion/#findComment-10879541
Yes here is the link:
The Cosmo Knight
Thanks
Specs:
Case: NZXT H440 Red
https://linustechtips.com/topic/879633-wallpaper-conversion/#findComment-10880755
Yeah its perfect, and do you mind telling me on how to do that so I know in future in case i want another wallpaper?
Specs:
Case: NZXT H440 Red
https://linustechtips.com/topic/879633-wallpaper-conversion/#findComment-10880845
Sure, open Photoshop > Ctrl + N > type these res.
bring the wallpaper to the photoshop:
select some of the right side
> copy > past > move it to cover the empty area
the left side as well
I know it's not a perfect solution, but it works
https://linustechtips.com/topic/879633-wallpaper-conversion/#findComment-10880871
I can't really tell, but I can see more triangles on the right side than the left, but that will not bother me.
Specs:
Case: NZXT H440 Red
https://linustechtips.com/topic/879633-wallpaper-conversion/#findComment-10880881
Thanks anyway, big help!
Specs:
Case: NZXT H440 Red
https://linustechtips.com/topic/879633-wallpaper-conversion/#findComment-10880882
