Hello,
In continuation to my introductory topic http://linustechtips.com/main/topic/85534-first-ltc-rig/ where, thanks to a lot of members of this beautiful community I learned a lot of useful information necessary in building LTC mining rigs, I now present you my build log. I'll update this first post with where I am in building and operating my LTC mining rigs and I hope we'll keep the discussion going down below.
12/12/2013
After constructing a few well planned investment and return scenarios, my girlfriend and me finally take the plunge and hit the buy button. We went on a hunt for a few weeks, searching in online outlets (Canadian) for mobos still in stock with matching cpu and ram and psus powerful enough for the multiple gpus that would be mining. We scavenged the local ads of resales of 7970s and 280xs weighing every offer and most of the time being baffled about how much people were asking for them. After a few confirmation clicks and trips around town, we finally placed the orders and have everything we need for two mining rigs.
Rig 1 (mine) :
- MSI FM2-A85XA-G43, AMD A4 4000, Gskill RipjawsX 2x4Gb 1333Mhz, 2 Corsair HX850
- Vapor-X 7970, Dual-X 280x, DCUII 280x, DCUII 280x
Rig 2 (gf's) :
- Dual-x 280x, Dual-x 280x, Dual-x 280x, DCUII 280x, DCUII 280x
We also found the powered pcie risers and the milk crates.
Shipment #1 has arrived
The 4 Dual-xs are used (1 week mining 24/7), but are flawless. I bought them at 400$ each. I tested the new psus by shorting the ON signal in the 24pin mobo connector. Fans spin but stop after a few seconds. Seems normal since there's a sticker stating that these are silent psus and that it's normal to have the fans not spin under low load. Risers were hard to find. I only have 1x to 16x ones so far, with extensions. Our 16x to 16x order is on back-order but should ship (express) Tuesday.
We have a few extra ram sticks because of an non cancelled order but we might just end up using them  :ph34r:. We have 2 extra mobos too because we bought the DCUIIs in a bundle with the mobos (great price). This weekend, there's a few more boxes that'll be waiting for me.
https://linustechtips.com/topic/87927-first-ltc-rigs-da-build/
Ill have all the extra stuff. (I will pay shipping! :D )
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/87927-first-ltc-rigs-da-build/#findComment-1191547
I have a feeling there won't be any...
Well you said you had 2 extra motherboards :S
https://linustechtips.com/topic/87927-first-ltc-rigs-da-build/#findComment-1191552
Dat cat!:D
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/87927-first-ltc-rigs-da-build/#findComment-1191558
for now
until you give them to me
https://linustechtips.com/topic/87927-first-ltc-rigs-da-build/#findComment-1191568
Since you have basically 9 7970 there. And they each produce eh 700 hashes. You would be putting out 6300 hashes which equivalents to about  $61 dollars a day adding in the cost of the power bill which is roughly about $4 dollars. A week $430 at the current difficulty and $1830 a month. Again at the current difficulty.
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/87927-first-ltc-rigs-da-build/#findComment-1191752
It really depends how much money you've invested in those cards and the rig in total.
https://linustechtips.com/topic/87927-first-ltc-rigs-da-build/#findComment-1191755
Keep a eye on those dual x's I had to RMA 5 of them because vrm temps would hover around 100c after 30 min and would pull back the core clocks to cool down. It was not a cooling issue,  I put them in a rig thats been running 7970's sine june with no probs. It seems to be a issue with the rev 2 cards b/c i have 5 day one 280x dual x that run just fine with my 7970 dual x.
https://linustechtips.com/topic/87927-first-ltc-rigs-da-build/#findComment-1191953
Very nice. Make sure you visually inspect the PCI extenders, check for solder bridges or other imperfections which may cause a short. Of all the components the pci extenders tend to have the lowest quality checks. If you're really paranoid you can check each individual pin using a multimeter.
You keep using that word. I do not think it means what you think it means.
Users cannot, and will not securely manage key material. Most users can't and the ones that can, wont.
Ask me about Bitcoin, Litecoin, Crypto-Currencies, and/or Mining them.
https://linustechtips.com/topic/87927-first-ltc-rigs-da-build/#findComment-1192235
Visual inspection it is.
https://linustechtips.com/topic/87927-first-ltc-rigs-da-build/#findComment-1192784
Does hwmonitor show vrm temps?
https://linustechtips.com/topic/87927-first-ltc-rigs-da-build/#findComment-1192788
Difficulty should rise by 250 soon but that's approximately how much we will make. Electricity costs practically nothing here.
https://linustechtips.com/topic/87927-first-ltc-rigs-da-build/#findComment-1192795
really?
https://linustechtips.com/topic/87927-first-ltc-rigs-da-build/#findComment-1193100
Really
lol kk.
https://linustechtips.com/topic/87927-first-ltc-rigs-da-build/#findComment-1193137
Do you think the r9 280x Vapor-x would be affected by that same issue ? I'm looking at offering someone 400$ for one.
https://linustechtips.com/topic/87927-first-ltc-rigs-da-build/#findComment-1193971
