Artifacts after paste replacement
1 hour ago, kosimiki said:What do you mean it isnt screwed down hard? I thought i should screw it until i can .
Sometimes if you screw down too hard it can cause problems - but if you don't screw down hard enough, you won't have good contact between the GPU and heatsink. This is just for future reference, as your problem seems to be elsewhere.
There is no harm in using it upside down, and if it works then it works, right? If you're sure the cables work and the connectors aren't filled with dust, there's likely a problem on the board itself. You can try troubleshooting further, but if it works upside-down and you're happy keeping it that way then I would leave it as is.
The only question remains, can I use it upside down like this or can I somehow fix it?
If do insist on fixing it and you want to troubleshoot, you can try the following:
- Check for faulty/loose wire from PSU
- Cleaning the contacts on the GPU
- Check for a loose screw (or anything that could be shorting out components)
- Check for loose solder joints
- Look into the GPU "oven fix"
