Hi, i'm pretty new when it comes to upgrading my pc very new in fact and, i think i've just made a rookie and bad mistake can anyone help me out and tell me if this system will be okay? Or needs to be adjusted before put together.
CPU - intel -7-7700k 4.2ghz    (was an upgrade)
GPU - evga geforce gtx1080 ti ftw3   (was an upgrade)
Motherboard and RAM - I didn't upgrade these this is what they currently are:
mobo - Asus P8Z68-V/GEN3
RAM - DDR3 Corsair 16GB 1600mhz
Mainly looking to game on this pc like ark etc.
Any help would be apprecaited thanks.
https://linustechtips.com/topic/876107-need-help-cpu-gpu-and-memory/
Your motherboard has the wrong socket. The Asus P8Z68-V/GEN3 has socket 1155 and the i7-7700K has socket 1151. This means you need to swap a socket 1151 (and a Z270) motherboard to get it working. This also means you need to upgrade ram.
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
