HELP Graphics Drives HELP PLEASE?
guys quick question
I will be moving from my INTEL Integrated graphics to a real HIGH end graphics card (relatively). And I was wondering what I should do about my intel display drivers? just leave them? delete them before installing the graphics card? or after?
Any other things I need to do before installing my nvidia graphics card?
Double check everything, I am usually wrong.
https://linustechtips.com/topic/87395-help-graphics-drives-help-please/
either way it's fine don't worry about it
install it in your motherbourd then install latest driver then done
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
SOO do I need to delete my intel ones?
like i said both way it's fine but you could do it if you want to
ExSystems
I have a 4670k and I installed the intel drivers, but I also have a gtx 770 Jet Stream GPU and then installed the Geforce Experience and that then installed the latest drivers for my GTX 770, I also use the latest drivers as they tend to be stable these day's.
You will be find if you leave the intel drivers installed.  :mellow:
Cry Havoc!
