Razer Surround Problem...
Hey guys, I just found out that my Razer Kraken actually has software after using it for half a year(Ima genius, I know) and I went to do the 7.1 surround calibration and after using it for a few minutes, I found out that if I play a video on YouTube and I pause, I get buzzing noise which is very irritating. Does anyone else have this problem or know a solution or should I just continue to use the Realtek HD sound thingy(can't remember the name). Also, can someone, if possible, recommend me a good all around EQ setting? I'm lazy to manually do it. Thanks!
Edit: Its not just when pausing, whenever I play something, it happens.
ASUS ROG G75VX
Intel i7-3630QM 2.4GHz/3.4GHz Turbo | Nvidia GeForce 670MX 3GB OCed to 736MHz | 750GB HDD | Windows 8.1 | 24 GB 1600MHz RAM | Razer Goliathus Medium | Logitech G400s | Razer Kraken/ JBL J22 | Corsair Vengeance K70 Cherry MX blue
https://linustechtips.com/topic/87365-razer-surround-problem/
Ok, nvm. I just solved my own problem. Its the sound normaliser. I set it to 100 and it makes that noise.
ASUS ROG G75VX
https://linustechtips.com/topic/87365-razer-surround-problem/#findComment-1184957
