I'm building a pc next month. Take a look on my list please
********   I'm on a really tight budget.   ***********
AMD RYZEN 3 1200
Gigabyte GA-AB350M-HD3 DDR4 AM4 Socket AMD Mainboard
GTX 1050 Ti
Corsair Vengeance 8GB DDR4 2400
Cooler Master MasterWatt Lite 500W
Toshiba DT01ACA100 1TB SATA 7200RPM
*** My question are following :  1) Can I overclock my CPU with this motherboard ?  (if i can't please refer me a motherboard)
                                                  2) Can I overclock my CPU to 3.6 GHz with stock cooler ?
Please help me :(
https://linustechtips.com/topic/872723-i-need-help-please/
it'll overclock, and it should oc to 3.6ghz on stock. but I'd look for an asrock ab350m instead. also, I'd suggest an i3 8100 if H310 boards are released by the time you order the parts.
https://linustechtips.com/topic/872723-i-need-help-please/#findComment-10817445
