Hello, my son wants a gaming PC. So to get the best one for my money, since I don't have a lot, I've been searching the web up and down about all the different parts! I found a nice curved monitor -MSI free sync - but i found out free sync monitors aren't compatible with Nvdia gpu or graphics cards and they seem to be the best PC. What graphics card and mother board are the best to make use of everything a free sync monitor has to offer? Also,  is a display port necessary in the monitor? Any additional details would be helpful? TIA
https://linustechtips.com/topic/872647-help/
First off you probably need to give us your total budget and if it includes peripherals (e.g. mouse keyboard monitor)
For FreeSync to work, you just need an AMD Graphics Card, and a FreeSync monitor, nothing else.
FreeSync only works over either DisplayPort and HDMI. Most monitors do it over DisplayPort but there are a few (e.g. LG monitors) that only do it through HDMI.
If you can give us the specific model number of the MSI monitor you found, we can check for you. But just off the top of my head, it'll be FreeSync over DisplayPort.
The motherboard doesn't matter for FreeSync functionality.
Karamo
CPU: AMD Ryzen™ 5 3600 | CPU Cooler: Wraith Stealth | GPU: Gigabgyte AORUS GeForce RTX 2070 Super | Motherboard: MSI B450M Mortar Max | RAM: G.Skill FlareX 2x8GB 3200MHz CL16 | SSD: ADATA XPG SX6000 Pro M.2 256GB | HDD: 1TB 2.5" Western Digital Blue (WD10SPZX) | Case: NZXT H510 | OS: Windows 10 Pro 64-bit |
https://linustechtips.com/topic/872647-help/#findComment-10816803
we can help with the built also if you need help.
Main rig                             I also got some cheep lg phone and a chromebook, witch I have been known to mine bitcoin on sometimes
CPU: R5 2400g
RAM: 8gb ram
MOBO: msi b350 pc mate
CASE: Eclipse p300
PSU: 500w corsair
https://linustechtips.com/topic/872647-help/#findComment-10816812
free sync will only work with a amd gpu's but this doesn;t mean it wont work with an nvidea monitor. That monitor will still work but the adaptive refresh rate will not work. If you can afford it a rx 580 would be good but don;t buy above msrp. this will give you free sync but I use a 1060 6gb
https://linustechtips.com/topic/872647-help/#findComment-10816850
