33 minutes ago, MrDrWho13 said:
Is the problem that you are typing and each letter removes the following letter? Or is pressing delete deleting the wrong thing?
I have no problems with typing, I have problem with delete button. when I write text and trying to delete it, nothing is happening, when I move the mouse cursor from end of the text to beginning, it deteles the following text. Perhabs it's a norm, maybe I only right now noticed that, because all the time was deleting texts with backspace..
Please report me whether it is a disconfiguration or standart.
https://linustechtips.com/topic/872068-how-to-fix/#findComment-10811593
You say your fn key is borked in the picture.  Is it possible it's acting like it's being held down?  Fn+Delete (when using the key that's where the backspace typically is) causes text to be deleted to the right of the cursor, rather than to the left.  It's intended for keyboards that don't have the other delete key, but I don't see anything that says it's otherwise disabled on keyboards that have one.
Current stuff:
Laptop:
Dell Inspiron 15 Gaming
Intel Core i5 7300HQ @ 2.50ghz
GeForce GTX 1050
32gb Crucial DDR4 2133
500gb Samsung 850 EVO
5TB Seagate Barracuda 5400RPM Laptop drive
Desktop:
Intel Core i7 6700k @ 4.20ghz
2x GeForce GTX 1080 Founders Edition
4x8gb GSkill Ripjaws V DDR4 2133
Gigabyte Z170X Gaming G1
480gb Kingston HyperX Predator
2TB Seagate Barracuda 7200RPM HDD
Corsair Strafe RGB w/MX Blue switches
Mad Catz R.A.T. 7
Lots of completely necessary "Go Faster" lights
Server:
Dell PowerEdge T30
4x Western Digital Blue 1TB 7200RPM Drives
1x4gb Hynix DDR4 2133 RAM
CoolerMaster CM Storm QuickFire Rapid w/MX Blue switches&Custom NVIDIA/QuakeCon keycaps
https://linustechtips.com/topic/872068-how-to-fix/#findComment-10811652
Don't pay attention for that, I just took picture from internet to show where insert locates in mac keyboard. I tried Fn+Delete just, nothing changed, as I said, perhabs it's a standart, how your keyboard act when you press delete?
https://linustechtips.com/topic/872068-how-to-fix/#findComment-10811689
When I press delete, it deletes characters to the right of the cursor.  When I press backspace, it deletes to the left.  But I have a traditional keyboard.
Current stuff:
Laptop:
GeForce GTX 1050
Desktop:
Mad Catz R.A.T. 7
Server:
Dell PowerEdge T30
https://linustechtips.com/topic/872068-how-to-fix/#findComment-10811691
36 minutes ago, MrDrWho13 said:
Are you using the right delete button?
Red will delete the character to the left of the cursor, blue will delete the character to the right of the cursor.
That's right, I thought that they both should delete only to the left side of the cursor..  thanks for clarification
https://linustechtips.com/topic/872068-how-to-fix/#findComment-10811933
