Nvida Drivers Help
Go to solution Solved by ahuckphin,
While using my desktop computer, Windows automatically installed an older Nvidia driver that supported my Nvidia Quadro 600. It's just that my internet isn't fast, and took a while before supported Nvidia drivers were automatically installed.
Upon putting my SSD back into my laptop, the laptop’s Nvidia GeForce 525m automatically detected some Nvidia drivers and worked.
So i have a laptop with GT525m graphics and installed driver 382.64. It took the SSD out of that laptop and put it into my desktop which has a Quado 600. Windows 10 booted right up and everything worked fine except sound, which wasn't a big problem to solve & the graphics. The Nvidia driver is still installed. However, the desktop computer chooses to use Microsoft Basic Display Adapter instead of the already installed Nvidia drivers. Where's the .inf file for Nvidia driver? Or does driver 382.64 not support the Quadro 600?
https://linustechtips.com/topic/871992-nvida-drivers-help/
https://linustechtips.com/topic/871992-nvida-drivers-help/#findComment-10816014
