I bought Seagate Expansion 2TB portable hard drive. First I installed SeaTools and run short and long test, everything compleated fine. After that I installed program Seagate drive settings program but it tells me that no external drives can be found (picture in attachment). Is this normal? I tried connecting it on front panel and on the back of my motherboard same results.
https://linustechtips.com/topic/869945-seagate-portable-problem/
Have you tried installing DiscWizard and seeing if the drive is seen there?
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
4 hours ago, ringo said:
Seagate support told me that program Seagate drive settings in not compatible with win 10 :D
What about those Smart settings, is everything OK? Raw read error rate 84 -65?
Hmm, interesting. I almost wonder if you could get it to work running it in compatibility mode.
As far as the health of the drive goes, you would check that using SeaTools running a Long Generic test. Seems the software you're using rates it okay, however we can't say for certain with 3rd party software.
I already said that it passes long generic test in Seatools but Seatools doesn`t have Smart check unfortunatley
