Greetings everyone,
I recently came across a broken Amazon Kindle Fire and want to fix it up for Christmas. It will not turn on from pressing down the power button, and it does nothing when I plug in a charger. I have seen multiple videos concerning this issue and many have proven that the usb port easily disconnects and creates an open circuit so that no power can get through. However, all of the videos I found were of usb ports that were physically disconnected from the pcb, while mine is still (somewhat) firmly in place. To either confirm or deny the port's operational state, I want to send power directly to the board. Which of the usb port's 5 pads on the pcb, and polarity, do I need to solder wires to in order to bypass the port, and what specific voltage and current?
Thank you.
Stephen
https://linustechtips.com/topic/869794-fixing-kindle-fire/
why don't you just plug in the usb charger and go for the pcb soldering points form the usb socket with a multimeter? no need to solder just measure if something is coming through.
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
https://linustechtips.com/topic/869794-fixing-kindle-fire/#findComment-10790075
