3x 290 and everything in my signature well not EXACTLY that build. But you get the point.
What psu
GO
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/86972-yet-another-psu-help/
Maybe not enough watts?
Exactly, what wattage should i get?
Main Rig
Phone
https://linustechtips.com/topic/86972-yet-another-psu-help/#findComment-1180054
I would say 860- 1000
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/86972-yet-another-psu-help/#findComment-1180058
1200W+ PSU
https://linustechtips.com/topic/86972-yet-another-psu-help/#findComment-1180066
I should look for a Corsair AX1200i. Looks like you got the money for it. Good luck :)
I don't. :D I was hoping to pay for it by mining, but i might go with 280x instead because they are cheaper ^^
Main Rig
Phone
https://linustechtips.com/topic/86972-yet-another-psu-help/#findComment-1180359
Also nice yh. But I'ld recommand using as high amount of watts as you can affort. believe me... You gonna get pissed off when you got some watts to short.
https://linustechtips.com/topic/86972-yet-another-psu-help/#findComment-1184001
