hi fellow members, how are you all?
yesterday i brought a pc and i need help on that
I brought core i5 3470 3.2 With gigabyte GA Z77HD3 and 4*2 total 8GB Corsair memory.
as i am new on this i don't know how to overclock also don't know how much should i do so please give me suggestion
Thanks in advance.
https://linustechtips.com/topic/8678-need-help-on-update/
Firstly what cooling for the cpu do you have ??? Are you on the stock cooler ???? or a aftermarket.
MB: Gigabyte Auros Gaming 7 Z370 Cpu: Intel i7 8700K @ 4.8ghz Gpu: Gigabyte GeForce GTX 1080 G1 Gaming OC 8GB Ram: Corsair Vengeance LPX 64GB DDR4 DRAM 2400MHz  Psu: Corsair RM1000i
Ssd's: WD Green nvme m.2 512gb (boot), 480gb (Steam), 480gb (Uplay) and 480gb (Origin)  Cooling: Corsair Hydro Series H115i 280mm
 Case: Corsair Obsidian Series 900D Monitors 1: Asus pb287q @ 75hz
https://linustechtips.com/topic/8678-need-help-on-update/#findComment-96791
thanks both of you. i understand this. can you also tell me that as i don't have any graphics card yet so what is the maximum i can use on board graphics. in default is show 64mb but there is a increase option.
also i install 8gb ram it's show only 7.70 usable. why ?
https://linustechtips.com/topic/8678-need-help-on-update/#findComment-96860
