Horizontal lines on screen Help
Solved by limegorilla,
It might be that the resolution you have the TV set to is not its "native" setting it can display the image your pushing to it, but not properly. Try and go lower or higher. And yes - other devices, such as games consoles, might display at that resolution just fine, but I think it has something to do with Windows. Other than that, I echo @Dujith, disable all post processing, (maybe try fiddling with HDR too) till you have a desirable image
