Hello I'm looking at building a gaming pc for about $2,000 or less. I would like for the pc to run windows( I'd like for it to be able to do everything else as well) . I'm trying to build the computer as soon as possible and would like for the pc to play all the newest game and gerally being good at other things. This is my first build and would like to spend less than $2,000 as I would like to spend the rest on peripherals as I don't have anything(I already have a few picked out). I still haven't decided on ryzen or Intel or amd or Nvidia. I'd also like to go with a m.2 or nvme drive.
Thanks to all you stop and help.
https://linustechtips.com/topic/867031-help-building-2000-gaming-pc/
hackintoshes aren't allowed in LTT, btw. might wanna edit that out and just ask for a gaming rig.
which peripherals do you need?
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($414.89 @ B&H)
CPU Cooler: Reeven - Justice 82.1 CFM Sleeve Bearing CPU Cooler  ($39.99 @ Newegg Marketplace)
Motherboard: Gigabyte - Z370 AORUS Gaming 5 (rev. 1.0) ATX LGA1151 Motherboard  ($149.99 @ Newegg)
Storage: Crucial - BX300 240GB 2.5" Solid State Drive  ($74.99 @ Amazon)
Storage: Toshiba - 2TB 3.5" 7200RPM Internal Hard Drive  ($61.88 @ OutletPC)
Video Card: MSI - GeForce GTX 1080 Ti 11GB DUKE OC Video Card  ($709.99 @ Newegg)
Case: Corsair - 270R ATX Mid Tower Case  ($60.99 @ Amazon)
Power Supply: Rosewill - 650W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($54.99 @ Newegg)
Keyboard: Logitech - G410 Atlas Spectrum Wired Gaming Keyboard  ($49.99 @ Newegg)
Mouse: Logitech - G502 Wired Optical Mouse  ($34.99 @ Best Buy)
Other: ADATA XPG GAMMIX D10 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Desktop Memory Model AX4U300038G16-DRG  ($143.99 @ Newegg)
Total: $1796.68
Generated by PCPartPicker 2017-11-29 20:18 EST-0500
Total: $1796.68
I need a mouse, keyboard, and a monitor. The 1080 ti I'd like to play on 1440p,  but nothing higher than that as I think it's not worth the lower frames. Thanks for the help.
CPU: Intel - Core i7-8700 3.2GHz 6-Core Processor  ($339.99 @ B&H)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard  ($124.99 @ Newegg)
Case: Cooler Master - MasterBox Lite 5 ATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($54.90 @ Newegg)
Monitor: Dell - S2417DG 23.8" 2560x1440 165Hz Monitor  ($379.99 @ Amazon)
Keyboard: Turtle Beach - IMPACT 500 Wired Standard Keyboard  ($49.95 @ Amazon)
Mouse: Corsair - Harpoon RGB Wired Optical Mouse  ($24.99 @ Amazon)
Total: $1995.65
Generated by PCPartPicker 2017-11-30 18:51 EST-0500
