Question about Lighting Node Pro before I RMA
Here is the issue, i turned on my PC and none of my Corsair LED's or fans lit up and in corsair link my lighting node pro (LNP) isn't recognised. I plugged the LNP into a different usb port on my NZXT internal USB hub and it seemed to fix it for a few days but then it happened again. I presume the issue is the LNP as I have other things plugged into the USB hub and they work fine. I am going to RMA the lighting node pro but I first want to know if anyone has had this issue or has a fix. The firmware is up to date and so is corsair link.
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
