Hey all. I Need some help, (I apologize if this is the wrong place to post) But I was wondering, how to Use my graphics Card Hdmi (One I'm using atm) But Also use VGA on motherboard ports for a Different monitor. I've done a tiny bit of "research" And It seems you can't do this. I'd need to get a DVI - VGA or something converter cable. (The monitor has DVI but so does the graphics card so i probably wouldn't need a converter, I just don't have a DVI cable atm). Thanksss
Ryzen 5 3600
RX 590 8GB
WD Blue 1TB
(full specs on profile)
https://linustechtips.com/topic/865692-motherboard-bios-help/
