Go for 8th gen cpus or ryzen 5 1600. Also for the 7600k you dont need a watercooler, Cryorig h7 is fine.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/864659-motherboard-for-pc/#findComment-10742754
https://ca.pcpartpicker.com/list/bvm7f8
Here, Id reccomend a better mouse btw.
My Rig
 Peripherals
https://linustechtips.com/topic/864659-motherboard-for-pc/#findComment-10742777
Also a 250 gb ssd. 128 fills up fast.
My Rig
 Peripherals
https://linustechtips.com/topic/864659-motherboard-for-pc/#findComment-10742780
6 minutes ago, Edu_X007 said:
And if I overclock the i5-7600k would I then need the watercooler?
Also, any reason for the r5 1600 over this one? (The intel 8th gen is above my budget)
7600k is a terrible processor, only 4c/4t and a little inferno.  Also the 7600k doesn't come with a stock cooler
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/864659-motherboard-for-pc/#findComment-10742835
7th gen is a terrible deal. With a budget of 1600 CAD you could do much more.
PCPartPicker part list: https://ca.pcpartpicker.com/list/CpLbWX
Price breakdown by merchant: https://ca.pcpartpicker.com/list/CpLbWX/by_merchant/
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($239.75 @ Vuugo)
Motherboard: ASRock - Z370 Pro4 ATX LGA1151 Motherboard  ($130.00 @ Vuugo)
Memory: G.Skill - Aegis 16GB (2 x 8GB) DDR4-2800 Memory  ($160.99 @ Newegg Canada)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive  ($99.99 @ Amazon Canada)
Storage: Toshiba - 2TB 3.5" 7200RPM Internal Hard Drive  ($69.99 @ Newegg Canada)
Video Card: EVGA - GeForce GTX 1070 Ti 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($604.99 @ Newegg Canada)
Case: Corsair - 270R ATX Mid Tower Case  ($69.99 @ Amazon Canada)
Power Supply: EVGA - 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($79.99 @ Amazon Canada)
Case Fan: Cooler Master - SickleFlow (Red) 69.7 CFM  120mm Fan  ($6.99 @ Amazon Canada)
Keyboard: Corsair - K63 Wired Gaming Keyboard  ($79.99 @ Amazon Canada)
Mouse: Redragon - Centrophorus M601 Wired Optical Mouse  ($17.99 @ Amazon Canada)
Total: $1560.66
Generated by PCPartPicker 2017-11-24 20:10 EST-0500
Desktop benching:
https://linustechtips.com/topic/864659-motherboard-for-pc/#findComment-10742870
Total: $1560.66
What would be the difference between the 7600k and the 8400, in both general work and games?
https://linustechtips.com/topic/864659-motherboard-for-pc/#findComment-10743071
1 minute ago, Alexsolo said:
8400 has more cores and threads. Base and turbo clock speeds are also much higher. 8400 doesn't require a big cooler or an overclock to achieve these better speeds and comes with a fan in the box.
What about mobo for it?
I was looking at the msi gaming plus and ASRock - Z370 Pro4
https://linustechtips.com/topic/864659-motherboard-for-pc/#findComment-10743094
14 minutes ago, Alexsolo said:
Personally I'd go with Asus, but if you're able to wait till next year I'd get a cheaper B360 or H370 board since it's better suited for a locked processor like the 8400 (no overclock)
Do you know around which month they are expected to come out? Also, I had found the msi one at around 130 CAD. Would the new ones be cheaper than that?
https://linustechtips.com/topic/864659-motherboard-for-pc/#findComment-10743155
2 minutes ago, Alexsolo said:
Well current gen B250 and H270 boards are around $100 and under
so I'd expect the same series boards of the 8th gen CPU's at around the same price.
I'm expecting them to drop sometime after Christmas (jan-march)
But a Z370 board would be a good buy as well if ever you upgrade the processor to something like a 8700K later on down the line.
Here's a board, Asus, 5 year warranty that I would recommend around $130
ASUS TUF Z370-PRO GAMING
I'm finding it around 200 CAD, too expensive for me at the moment.
https://linustechtips.com/topic/864659-motherboard-for-pc/#findComment-10743183
Just now, Alexsolo said:
No the H100i has 2 fans, you'd hear them more than the single fan of an I5 8400
and if you go the 7600K route, i'd get a Noctua NH-D15 since air coolers are more reliable than AiO water coolers.
https://ca.pcpartpicker.com/list/MsvNRG
This is what I have right now. And if not the H100i, what would you recommend?
https://linustechtips.com/topic/864659-motherboard-for-pc/#findComment-10743319
Stock cooler is already enough to keep the locked 8400 cool while staying quiet. You can undervolt the CPU to further lower the temps if you wish. Also using slower memory to spend more on the graphics card will give better performance overall.
Desktop benching:
https://linustechtips.com/topic/864659-motherboard-for-pc/#findComment-10743374
