I need help
I have all the hardware but cant figure out the software
I have a backup server built with 2x 320gb and 2x250gb drives i had lying around then I bought 2x 8tb drives
I have freenas installed on the server and I have tries 3 different times to get a samba share I can add to windows file history (on my gaming desktop)
at first I just made a volume with the origional 4 drives and made a samba share in it, I could mount it on my pc and login with the account I made on the freenas server but windows refused to let me back up to it
so then I looked up windows stuff and tried to enable active directory but that just made it so i couldn't mount the share anymore
now I have the 8tb drives and im looking at the "share modules trying to figure it out but I just dont know what I need to do
if anyone could tell me exactly what I need to do to setup this server to make a samba share I can add in windows backup I would be really greatfull
(between every try I hookup a monitor to the server and use the console reset to factory defaults option)
cTurtle98 - Desktop
CPU: i7 7700k
COOLER: Thermaltake - Water 3.0 Extreme S
MOBO: Asrock z270 killer sli/ac
RAM: G.Skill Trident Z 32 GB (4 x 8 GB) DDR4-3200
SSD 1: Intel - 600p Series 1TB M.2-2280 (Windows)
SSD 2: Samsung 970 Evo 1 TB M.2-2280 NVME (POP_OS)
GPU: MSI - GTX 1070
PSU: EVGA - SuperNOVA G2 550W 80+ Gold Fully-Modular
CASE: Thermaltake - Versa H26
cTurtle98 - Portable PC
CPU: R5 1600
COOLER: NH-L9a-AM4
MOBO: ASRock - AB350 Gaming-ITX/ac
RAM: 16GB (2 x 8GB) Corsair - Vengeance LPX DDR4-3200
SSD 1: Intel - 600p Series 512 GB M.2-2280 (Windows)
SSD 2: 860 Evo 1 TB 2.5" (Manjaro)
SSD 3: PNY - CS1311 120 GB 2.5" (POP_OS)
GPU: Gigabyte GeForce GTX 1650 4 GB MINI ITX OC
PSU: HDPLEX 400 AC-DC DC-ATX Combo
CASE: NFC Skyreach 4 mini
https://linustechtips.com/topic/864653-help-setting-up-freenas/
Are you mounting it to a drive letter and then trying to backup to the drive letter? I don't think Windows Backup supports backing up to a UNC path.
If you understand volume shadow copy / file versioning, read below.
File history / Versioning will work for files that exist on the NAS, not files that exist on your PC and you'd like to put versions/history via VSS onto the NAS. If you're looking for file versions for files that exist (or ones you plan on putting) on the NAS, then use FreeNAS snapshots which will advertise the versions to windows so you can go to properties > previous versions.
https://linustechtips.com/topic/864653-help-setting-up-freenas/#findComment-10752801
I was trying to setup active directory because I thought that was my problem but I eventually gave up on that and got rid of it and restarted from scratch and now it suddenly works, I was able to connect to my freenas in both windows backup and restore (control panel) and windows backup (system settings)
not sure what I messed up before
cTurtle98 - Desktop
CPU: i7 7700k
GPU: MSI - GTX 1070
CPU: R5 1600
COOLER: NH-L9a-AM4
https://linustechtips.com/topic/864653-help-setting-up-freenas/#findComment-10754535
Just a few tips.
  • Always check your firewall settings
  • Check your network IP settings (DHCP or Static etc)
  • create proper users and user groups with proper access rights on the NAS
  • having mounted the volumes on the NAS check and if necessary restart the proper services to enable sharing
  • check the share settings that are mapped to the proper volume share on the nas.
https://linustechtips.com/topic/864653-help-setting-up-freenas/#findComment-10756625
15 minutes ago, TonyStark said:
Just a few tips.
Ok so let me see if I'm doing this right
I made a group called "OWNER" then I made a user for myself and made that my primary group, then I made groups for my backup and storage datasets and I added those as auxiliary groups for mine
In my user on the Nas I added the email for my Microsoft account that is logged in on my PC and checked the box saying Microsoft account but it still asked for my password, does my password need to be the same for the Nas and Microsoft for that to work ?
I set a static IP on the server, that was the first thing I did
THANK YOU SO MUCH FOR THE HELP
cTurtle98 - Desktop
CPU: i7 7700k
GPU: MSI - GTX 1070
CPU: R5 1600
COOLER: NH-L9a-AM4
https://linustechtips.com/topic/864653-help-setting-up-freenas/#findComment-10756670
If yu set the same username and password on the NAS user, then you will not have to log in every time to the NAS share or enter your credentials.  .
Also If you do not have an infrastructure (greater than a couple of PC's and the NAS) you do not need to set up a domain on the NAS or on a Server (physical or virtual).
https://linustechtips.com/topic/864653-help-setting-up-freenas/#findComment-10756676
My network is my desktop, my laptop my videogame server (factorio and Minecraft) and my web / media (emby) server so I don't think I need domain, also the servers are debian
cTurtle98 - Desktop
CPU: i7 7700k
GPU: MSI - GTX 1070
CPU: R5 1600
COOLER: NH-L9a-AM4
https://linustechtips.com/topic/864653-help-setting-up-freenas/#findComment-10756691
ok, then just make an user account for each user on each machine (one for your desktop, one your your laptop etc) and you can simply log in with thise at once.
also FreeNAS supports natively Linux OS (since its based on FreeBSD) and it has a plug in for Minecraft Server :)
https://linustechtips.com/topic/864653-help-setting-up-freenas/#findComment-10756696
