7 minutes ago, AZwiftW said:
So which one is positive and which one is negative for the Power and Reset switches?
Since they are switches, they don't have a positive or negative. They simply close the circuit for a split second.
You can install them in any orientation
75% of what I say is sarcastic
So is the rest probably
https://linustechtips.com/topic/863812-power-and-reset-switch/#findComment-10736048
