Keep fans on or off?
Solved by W-L,
2 minutes ago, BDev said:Simple question. I have some extra coolers in my case, and they are quite silent so putting them on low or off makes absolutely no "sound difference" but i just wanted to know if i should or not keep them on at all while my PC is idle / passive mode or while browsing the internet, because for me it makes no sense as my GPU is often at 27°C (i have no idea What's my CPU temp but it's cooler is like ALWAYS at high rpms so i don't really care). So, should i let them on or off?
If you want your system as dead silent as possible having them stop isn't a bad idea, they can turn on a ramp up if needed when the system get warm enough. If your CPU cooler is at high RPM check your temps or fan curves to see if it's one of the two reasons.
