Headset broke need help
50 minutes ago, RidDIs said:
no i dont want to fix the wire i want to disable one of the speakers and make it mono or whatever
Think that would require you to solder the other wire to the other driver, or something along that line, the wires are just set up like that. guess you could get a mono cable cut off the old cable and solder that together.
https://linustechtips.com/topic/862423-headset-broke-need-help/#findComment-10728561
