Reduce maximum volume?
Go to solution Solved by Hyrikan,
Check the driver of your sound solution (onboard/soundcard). Normally you should find an Option to lower the Volumes for left and right seperately. If you turn both down equally your maximum volume should go down.
So, I recently got the Logitech G930 and I love it. The thing is, it's way too loud. Anything over 35% volume is too loud for me. I was wondering if there was a way to lower the max possible volume in Windows 7. I hate having my sound slider at the bottom all the time.
https://linustechtips.com/topic/86242-reduce-maximum-volume/
xxzFbNA.png Simply do this? Or are you referring to this slider? (instead of the physical one on your headset)
https://linustechtips.com/topic/86242-reduce-maximum-volume/#findComment-1171135
  • Primary PC: i7-3770K@4,6GHz | Thermalright Macho | ASRock Z77 Extreme 4 | 16 GB Corsair Vengeance@1866MHz | 2x Gigabyte 660ti 3GB@1130MHz | 256 GB Samsung 840 | WD Black 1TB | BeQuiet! DarkPower Pro 650W | Zalman Z11
  • Secondary PC: i7-860@3,1GHz | Scythe Katana 3 | ASUS Maximus III Formula P55 | 8GB Corsair Vengeance 1600MHz | 2x Zotac GTX 280@650MHz | WD Velociraptor 500GB | Seagate Barracuda 2TB | BeQuiet! DarkPower Pro 750W | Coolermaster Cosmos S
https://linustechtips.com/topic/86242-reduce-maximum-volume/#findComment-1171136
reduce the preamp, click the sound button, then click mixer and turn that b**ch waay down.
Listen if you care.
https://linustechtips.com/topic/86242-reduce-maximum-volume/#findComment-1171161
