First build checking help
Go to solution Solved by Joshhelberg,
Sorry forgot wifi card here finished list https://ca.pcpartpicker.com/list/VM2JYr add 16gb don't mix ram kit cause problems
I am building a pc very soon for 3d work in blender and my brother will be playing games on it. Can someone check my pc build so that I am not messing something up? Also, is there anything I should change to lower the price? I am on a really tight budget here.
https://ca.pcpartpicker.com/list/ZCZN3F
thanks,
https://linustechtips.com/topic/862140-first-build-checking-help/
what's your budget?
1 minute ago, jblflip5 said:
$1450 cad incude the extra costs of keyboard and mice, nearly $100
so $1550 for everything?
2 minutes ago, jblflip5 said:
No, 1400-1450ish cad for everything
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($229.99 @ Amazon Canada)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  ($109.99 @ Amazon Canada)
Memory: ADATA - XPG Z1 16GB (2 x 8GB) DDR4-2400 Memory  ($192.99 @ Amazon Canada)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive  ($99.99 @ Amazon Canada)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($54.95 @ Vuugo)
Video Card: MSI - GeForce GTX 1070 8GB Video Card  ($526.49 @ Amazon Canada)
Case: Deepcool - D-Shield ATX Mid Tower Case  ($39.99 @ Amazon Canada)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Memory Express)
Wireless Network Adapter: Gigabyte - GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($44.99 @ Memory Express)
Monitor: LG - 27EA83-D 27.0" 2560x1440 60Hz Monitor
Keyboard: ROCCAT - Ryos TKL Pro Wired Gaming Keyboard  ($40.49 @ Amazon Canada)
Mouse: Thermaltake - TALON Wired Optical Mouse  ($23.50 @ Vuugo)
Total: $1423.36
Generated by PCPartPicker 2017-11-19 23:18 EST-0500
get os from reddit for $25 USD.
6 minutes ago, jblflip5 said:
I would like the same case and over lock ability because blender is highly dependent on both cpu and gpu
Your case choice doesn't have very good airflow going to be hard on cpu and gpu. here my version of your part list
3d work makes lots of heat so cooling is the most important thing to worry about
https://ca.pcpartpicker.com/list/qFxptJ
Looks pretty solid, just a few things.
I'm not sure why you're getting two totally different memory kits, especially considering how picky and stubborn Ryzen can be with memory. If you're getting more than one kit, make sure they are identical or at least very close. Although it's not a massive deal, It'll save you a lot of potential trouble. Note: You'll want at least 16GB for Blender.
The power supply you chose isn't very good. I'm not sure what the best cheaper power supplies are nowadays, so I'll leave it to somebody else to let you know about that or you can check out the PSU tier list posted in the PSU section of the forums.
First I've seen the case, but it doesn't look all that appealing in performance and functionality. I'm not a big fan of the appearance either, but that's on you (from my experience, the flashy "gamer look" gets old after a while).
Everything else looks good.
Desktop - CPU: Ryzen 7 3700x | COOLER: be quiet! Dark Rock 3 | MOBO: ASRock X370 Killer SLI/ac | RAM: 32GB Corsair Vengeance LPX 3200MHz | GPU: MSI RTX 2070 Super Gaming X Trio | STORAGE: 2x XPG SX8200 Pro 1TB, Crucial MX300 525gb, Seagate Barracuda Pro 4TB | CASE: Phanteks P400s TG White | PSU: Corsair HX750i
Laptop - Dell XPS 13 | Intel i7 7500u | Intel HD 620 Graphics | 8GB RAM | 256GB M.2 SSD
Peripherals - KEYBOARD: KBD67 Lite w/Gateron Milky Yellow Pros | MOUSE: Razer Deathadder V2 | AUDIO: Sennheiser HD 6XX, Truthear Hexa | MONITOR: Dual 1440p 27" MSI Optix MAG274QRF-QD
all of AMD's ryzen lineup will overclock.
Total: $1423.36
A very big thanks to everyone!
bad quality psu, get the cx450/m instead.
