Hi, I know that the overvoltage of graphics cards puts more heat and reduce the life time of the card but I couldn't find clear answers to my questions on the interweb so I'm asking you guys:
When do I have to overvolt my GPU during an overclocking? (When do I know I have to crank the overvoltage to continue overclocking?)
How do you use the overvoltage, directly maxed out or do you have to increment?
Thank you. :)
https://linustechtips.com/topic/86153-questions-about-overvoltage-when-overclocking/
Well, after raising the frequency you will need to over volt when you see that:
A) Your driver crashes
B) There is a direct X error
C) There are a lot of artifacts
D) Any other graphical issues
And remember to raise voltages and frequencies in intervals.
EDIT: Ignore the smiley face. You can figure out what went wrong there lol.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
If you max out you will kill your card. To put it simply you start overvolting when you're starting to reach clocks that aren't stable anymore, however overclocking is a game with many variables and it will take a while to find good values for all the settings in order to reach the maximum stable clock.
You don't need over voltage unless you are crashing at the OC you want to use.  Typically I try to find the max OC I can run at stock voltage first then the max OC I can run at max voltage.  Certainly higher than stock voltage contributes to premature failure of the GPU but typically software voltage limits for cards are very conservative and shouldn't be any cause for alarm.  My Titans, for instance, are capped by Nvidia at 1.212V over voltage but ustilizing the AB hack allows for 1.3V (1.325V with LLC disabled) and I'm more than comfortable running that voltage.  Just remember that when you OC go up in small increments and when you start crashing, add voltage to stabilize.  Or do what I do and set max voltage first, then add clock speed until you crash...
Intel Core i7 4930K @ 4.7GHz | Asus Rampage IV Extreme | 2 x EVGA GTX Titan SC (1254MHz) | 16GB Patriot Viper Extreme DDR3 2133MHz (4 x 4GB) | Corsair AX1200 | Silverstone Temjin TJ11 | Corsair Force 3 240GB (System) | 2 x Intel 320 160GB SSD (Dedicated Gaming Drives) | Hitachi Deskstar 1TB (Data) | MS Windows 10 Pro | EK Supreme HF/FC-Titan/Rampage IV Extreme blocks | Hardware Labs GTX 560/240 rads | Alphacool VPP-655 D5 pump | Bitspower mod kit/pump top/fittings/120mm res
