If your case can fit it a Corsair H115i.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/861363-which-aio-cooler/#findComment-10714161
2 minutes ago, OhhhZenix said:
the phanteks eclipse p400s won't support a 360 rad (if you want an HDD),  2 case I have never heard of or seen, 3 case would support a 360 rad. i assume you live in the us
ask me about your system builds, AIO's, CPU's, PSU's, and GPU's.
https://linustechtips.com/topic/861363-which-aio-cooler/#findComment-10714232
welp do you have any suggestion for case? that has good airflow
https://linustechtips.com/topic/861363-which-aio-cooler/#findComment-10714236
p400s has good airflow but you could save some money and go with the p300 and throw in a 240mm rad like this one https://www.newegg.com/Product/Product.aspx?Item=N82E16835214061
https://linustechtips.com/topic/861363-which-aio-cooler/#findComment-10714238
3 minutes ago, OhhhZenix said:
k thanks for the suggestion
o ye and if you want to control the RGB wit software you would need this cable https://www.newegg.com/Product/Product.aspx?Item=N82E16812987031&cm_re=RGB_LED_ADAPTER-_-12-987-031-_-Product
https://linustechtips.com/topic/861363-which-aio-cooler/#findComment-10714259
