Rendering and VR Build help
Go to solution Solved by DocSwag,
11 hours ago, hjdaboss123 said:
Ok, thx, like this maybe?
https://pcpartpicker.com/list/PWjVJV
Edit 1: I mean this, https://pcpartpicker.com/list/B7gMRG
Yeah. It's up to you if you want to spend the couple of extra bucks for the better performance and higher capacity on the ssd but either way it looks good.
Looks good; I would get a different mobo (maybe a B350 strix, x370 prime pro, or x370 gaming 5 instead) and also get a different gpu (cheaper 580 or 1060 6gb instead) but other than that it looks good.
What will this pc be used for?
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
Read the title, and also, b350 strix is not avilable in Hong Kong and the rest are all 20 dollars more than the killer, but is the prime x370 pro better?
Derp... I'm an idiot.
I would probably go for a 1060 6gb then for CUDA.
The prime is definitely a lot better but as you mentioned it does cost more. The main reason I suggested it is because the vrms on the killer aren't that great considering the price you're paying.
You could also look into a cheaper option, such as the prime Plus or pro4
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
Would the prime be better than the gaming 5?
Like this?
https://pcpartpicker.com/list/GCFncc
Or like this?
https://pcpartpicker.com/list/zPgc2R
This looks pretty good.
It looks like the main differences are:
  • Different bioses
  • Gigabyte has way more rgb
  • Gigabyte has 2 gigabit Ethernet ports vs the prime's one (though most likely this won't matter to you)
  • The gigabyte has more and better USB ports
  • The Asus board has support for 3.1 gen 2 front panel USB ports (USB ports on your case), whereas the gigabyte only has 3.1 gen 1 ports
  • The gigabyte has one extra fan header
  • The gigabyte has some buttons on the board (power button, reset button, clear cmos button) built onto the mobo whereas the Asus has jumpers
  • The gigabyte has dual bios
  • The Asus has arguably slightly better vrms, though for a 1600 it won't really matter.
Looking over specs I think it's fair to say the gigabyte board is better in nearly every way, though it does usually cost more.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
  • Different bioses
Would this part list be good?
https://pcpartpicker.com/list/RqrjtJ
Found the MasterBox Pro 5 Appealing/
Looks good.
Only thing I might change is the ssd, as the su800 is not the greatest. I would look for something like an ultra/blue 3D, MX/BX300, SL308, or 850 evo instead if you can but it looks like you have it for a pretty good price so chances are it's the best deal there is.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
6 hours ago, DocSwag said:
Looks good.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
