im thinking of upgrading my setup and i would like to know if this is a good/decent upgrades. https://gyazo.com/9bac463025b16e0f896007240ed99772.
my current setup is
cpu : amd fx 6300 6 core
graphics card : gtx 760
Mobo : MSI 760GM-P23 (FX) AM3+ AMD 760G + SB710 Micro ATX AMD Motherboard
psu : i forgot wich 1 exactly but its like a 700+w
ram : just regular ddr3 6gb
monitor: asus 144hz
im trying to get an avrg of 250fps. will this be achieved with these new parts? i dont know if i should get the i3 or keep this fx 6300.
https://linustechtips.com/topic/859862-help-with-upgrades/
I would recommend getting a core I7 7700k or 8700k. Also hitting 250 frames in a newer title for example is very hard, i'm pretty sure 2 titans could even hit 250 frames in a newer title. So upgrade to a 1070ti if you can.
Former Bronze Contributor
CPU: Intel i7-7700K 4.2 GHz / CPU Cooler: Cryorig H7  / Board: ASRock Z270 Taichi / GPU: Nvidia 1060 6gb EVGA SC / GPU Cooler: NZXT Kraken G12 with Thermaltake Water 3.0 120mm RAM: White Corsair Vengeance LPX 16GB DDR4 2666 MHz SSD: 2x Samsung 850 Evo 250 and 3TB WD blue HDD / PSU: Corasir 550cx / Case: NZXT s340 Elite White
Im a super Italian. Kapish.
https://linustechtips.com/topic/859862-help-with-upgrades/#findComment-10698886
1 minute ago, Alphabet said:
i might just get the 1050ti and see what that gets me. if im still not satisfied what should i upgrade next, mobo and cpu?
if you're willing to wait till Q1 2018, i3 8100+H310 mobo or see what ryzen+/2 has to offer. otherwise ryzen 1200.
https://linustechtips.com/topic/859862-help-with-upgrades/#findComment-10698908
for everything now:
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  ($99.99 @ Amazon)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($40.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (1 x 8GB) DDR4-2666 Memory  ($79.99 @ Newegg)
Video Card: MSI - GeForce GTX 1050 Ti 4GB Video Card  ($154.89 @ Amazon)
Total: $375.85
Generated by PCPartPicker 2017-11-14 22:48 EST-0500
sell off the old hardware to get some money back.
https://linustechtips.com/topic/859862-help-with-upgrades/#findComment-10698915
Just now, Alphabet said:
so what would you do if this was your build?
upgrade both cpu and gpu if in budget, or get the best gpu now and plan for a cpu upgrade in the future if you don't have enough.
https://linustechtips.com/topic/859862-help-with-upgrades/#findComment-10699056
if i get another cpu i have to buy another mobo. what do u mean by best gpu, a 1080? i have like 170$ ish. i was thinking maybe buy a 1050ti and upgrade cpu and mobo later. i want a decent pc on a budget so what would u buy if u were doing a budget pc build
https://linustechtips.com/topic/859862-help-with-upgrades/#findComment-10699068
as in best that you can afford. for $170, get a 1050ti new or a used gtx 970.
https://www.ebay.com/itm/GeForce-GTX-970/222713578986?hash=item33dac385ea:g:Ic8AAOSwoR9aBSNZ
Edited by herman mcpootis
https://linustechtips.com/topic/859862-help-with-upgrades/#findComment-10699328
9 minutes ago, herman mcpootis said:
what's your current budget?
He has $170.
OP- IMO your best option would be to try and find a used card, options are pretty limited with a new one.
Intel i7-7700k @ 5.1ghz | Asus ROG Maximus Hero IX | Asus ROG Poseidon Platinum 1080ti @ 2126mhz | 64gb Trident-Z DDR4 @ 3600mhz | Samsung 960 Pro 1tb @ 3500mbps/2500mbps | Crucial 240gb SSD | Toshiba 4tb 7200rpm HDD w/ Crucial 128gb SSD cache | Corsair Hx1000i PSU | EK 360mm Coolstream XE Radiator | EK-Supremacy Evo Waterblock | EK-DDC 3.2 PWM Elite Edition Pump | EK-RES X3 150 RGB Reservoir | Primochill AdvancedLRT Clear Tubing | Primochill VUE UV Blue Coolant | Corsair 570x Crystal RGB Case | 4x 30cm CableMod UV/RGB Widebeam Hybrid Led Strip | 3x 120mm Corsair SP120 RGB Fans | 3x Noctua NF-A14 iPPC 3000rpm Fans | 3x Noctua NF-A12x15 Fan | CableMod ModFlex PSU & SATA Cables | Asus ROG Swift 27" 4k IPS w/G-Sync & LG UD68 27" 4k IPS w/Freesync |
https://linustechtips.com/topic/859862-help-with-upgrades/#findComment-10699372
30 minutes ago, Alphabet said:
what about a 950 dual fan for 60$ from my friend? would that be a good decision?
The benefit of going used is possibly finding a card better than the 1050 ti for your price range. Maybe along the lines of a 970 if you get lucky. Or even a decent 1060 maybe.
If you can't find something better than a 1050 ti used, I would go with the 1050 ti.
https://linustechtips.com/topic/859862-help-with-upgrades/#findComment-10702052
so i shouldnt buy my friends 950 for 60$?
https://linustechtips.com/topic/859862-help-with-upgrades/#findComment-10702057
I wouldn't, no.
https://linustechtips.com/topic/859862-help-with-upgrades/#findComment-10702064
