Unity Issue (C#)
Go to solution Solved by charles245,
I'll go test it myself to be sure, but it looks like you forgot to initalize your 2D array upon calling the GenerateMap function.
I'm trying to get a simple map generation script to work. Here's my code:
using System.Collections;
using System.Collections.Generic;
using UnityEngine;
public class GenerateLevel : MonoBehaviour {
	public GameObject square;
	public GameObject[,] map;
	void Start ()
		GenerateMap (20, 10);
	public void GenerateMap (int x, int y)
		for (int a = 0; a < x; a++)
			for(int b = 0; b < y; y++)
				Vector3 vect = new Vector3 (a, b, 0);
				GameObject tile = (GameObject)Instantiate(square, vect, Quaternion.identity, this.transform);
				map [a, b] = tile;
Basically, I have this script attached to an object in the scene and have a valid prefab reference to the "square." I have no other code or scripts but this. When I run the scene, the program begins to gobble RAM until it crashes. A couple of times, it spawn one square and said that there was an null object reference to tile at "map [a, b] = tile;"
Please help.
ORANGE SCREEN WINDOWS 10 VALUE OVER TIME - PC VS MAC
i5 7600k @ 5.0 GHz xD
Corsair H60 with Noctua NF-F12 iPPC-3000 PWM
MSI Z270-A Pro Motherboard
EVGA 1050 Ti SC
16 GB Corsair DDR4 @ 2400 MHz
500 GB Sandisk 950 PRO - Windows 10, Elementary OS, Zorin OS
500 GB Sandisk 850 PRO
1 TB WD Blue
Corsair CX750
1 x Corsair AF120 Quiet Red Led
Rosewell Tyrfing Case
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
24 GB DDR3 @ 1600 MHz
250 GB SanDisk 850 EVO - Elementary OS, Windows 10, Debian
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
8 GB DDR3 @ 1333 MHz
240 GB SanDisk - Windows 10, Linux Mint
https://linustechtips.com/topic/859800-unity-issue-c/
I just found the problem, I did:
and not:
for(int b = 0; b < y; b++)
However, I still am having a problem with this:
"null value found where object instance required at line 23"
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/859800-unity-issue-c/#findComment-10698216
Oh ok, now I get what you are saying. I'll go test that.
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/859800-unity-issue-c/#findComment-10698218
and not:
Oh, of course! Can't believe I ran right past that myself. Anyways, to fix the other error just initalize the array in the function.
map = new GameObject[x, y];
https://linustechtips.com/topic/859800-unity-issue-c/#findComment-10698221
Yep. That was issue number 2. Thanks!
EVGA 1050 Ti SC
1 TB WD Blue
Corsair CX750
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
https://linustechtips.com/topic/859800-unity-issue-c/#findComment-10698222
