corsair hd120 rgb Corsair HD120 RGB fan light Problems!
Solved by W-L,
4 hours ago, VillainCloud said:Nop, I don't have it! Just got only the fans!
So without the Corsair fan hub they won't work?
Or there are other ways to get them work?
No they will not work the fans must be connected to the RGB hub for any kind of lighting control, or the lighting node pro if you want software controllable lighting.
Featured Topics
Sjokk ·
Posted in Troubleshooting3 -
4
Trembletop ·
Posted in Graphics Cards13 -
6
2
VA7EC ·
Posted in Troubleshooting2 -
username1234 ·
Posted in New Builds and Planning14 -
Troxt ·
Posted in Troubleshooting4
play_circle_filled
Latest From ShortCircuit:
I'm a Huge Sucker for a Cool Gimmick - Epomaker DynaTab 75X & DynaTab 75
play_circle_filled
Latest From Mac Address:
The Apple Vision Pro Leaves a Mark (but not the right kind)
