PLEASE HELP. no voices??
I use the focusrite solo gen2 usb with at2020 and hyperx cloud 2's and for some reason it does not pick up voices, everything but voices sometimes they are there but very faint. with music, youtube, discord everything. please dont tell me to "jiggle the jack" because thats all i can find online and it isnt working. also i use a adapter for my loud2's to the focusrite jack
https://linustechtips.com/topic/859503-please-help-no-voices/
okay just for anyone that finds this thread in the future. i found a thread on a  random site and fixed it. you need to change the mixer balances so the left is at 80 and right is 50
1. Go to sound icon and right click. 2. Click on playback devices. 3. Click on the speakers and then properties. 4.Go to the levels tab and click balance 5. Set the left (L) one on 80 and the right (R) one on 50
https://linustechtips.com/topic/859503-please-help-no-voices/#findComment-10695167
Some voice chat softwares will choose a different output.
Make sure that "Headset/HyperX Cloud" or whatever you've named it as is chosen as output.
If it's not.. Well you wont hear anything.
You can do this via the audio settings in each software.
Ex. Speakers may be chosen instead of your headset.
https://linustechtips.com/topic/859503-please-help-no-voices/#findComment-10695169
Why would someone do that..?
That would just make the sound unbalanced, right?
Making the right one "less loud" than your left cup?
Are your clouds hooked up to the audio interface?
I have pretty much the same setup and that's not the way to go
https://linustechtips.com/topic/859503-please-help-no-voices/#findComment-10695174
it doesn't sound unbalanced. sounds perfect actually so idk
https://linustechtips.com/topic/859503-please-help-no-voices/#findComment-10708755
