Hello all! New member, came for some advise, I regularly watch LTT on the youtubes. I think I am finally comfortable enough with the thought of building compared to ten years ago when I first looked at it.
Finally moving away from laptops to get back to a desktop. I have a parts list ( https://pcpartpicker.com/list/KFr9bj ) and would really like to keep the case, or something with roughly the same dimensions, my desk is small and with my kiddos running around all the time I need to keep it up there and compact to save a little room.
My budget is 600, and I’ll need a windows key which I think I’ll obtain from Paul’s Hardware’s video about cheap keys, and that cost doesn’t figure into the build.
Wife wants the pc to be able to play sims 4 and expansions, I want Civilations 5 at least, I plan on trying to upgrade CPU and GPU next year.
Please take a look look and let me know if there are better options for budget.
Thanks!
-Mount
edit: updated part list to correct case with PSU.
Edited by mountopher
https://linustechtips.com/topic/857893-my-first-build/
Oh no! Color me embarrassed, thanks for pointing that out!!
I’ll have to squeak one in. I can go above 600, it cuts into my game budget, but clearly I’ll need one. Any recommendations, besides jumping to that version of the case? Which is also fine if necessary.
https://linustechtips.com/topic/857893-my-first-build/#findComment-10679389
https://www.evga.com/products/product.aspx?pn=110-BQ-0500-K1
The Darkened Phantom(With some light shining through)
CPU: I7-8700K @4.9Ghz 1.313 V Core
COOLER: Corsair H115i
GPU: 1070 Founders Edition @Stock settings
RAM: 16GB DDR4 CL14 TEAM GROUP DARK PRO 8PACK Hand picked Samsung B-Dies @ 3200mhz
PSU: Corsair RM 850X
CASE: Enthoo Pro M Special Edition
STORAGE: 1X 128GB SSD, 1X120GB SSD, 1 X 500GB NVME PCIE SSD and 1X 2TB HDD
https://linustechtips.com/topic/857893-my-first-build/#findComment-10679424
Just now, seon123 said:
You won't fit an ATX PSU into a case that only supports SFX
Oh shit yeah. Huge durp forgot it was a node
https://linustechtips.com/topic/857893-my-first-build/#findComment-10679444
This one should fit and be ample to power the system.. http://www.silverstonetek.com/product.php?pid=342&area=en
https://linustechtips.com/topic/857893-my-first-build/#findComment-10679449
I don't know how good the Integra M that comes with the Node 202 is. I wasn't able to find anything about it.
The SF450 for $90 is a good SFX PSU, which is fine for upgrades. Shouldn't have issues running a 1080 + 1700.
https://linustechtips.com/topic/857893-my-first-build/#findComment-10679483
2 hours ago, mountopher said:
The fractal 450W has decent reviews, I’m going to probably grab the case at the higher price point, I didn’t realize I grabbed the wrong one.
The PSU that comes with it is apparently crap. Decent SFX PSUs are expensive.
https://linustechtips.com/topic/857893-my-first-build/#findComment-10680189
Darn. Is it something that needs to be fixed before I get the parts, or can it wait a year. Don’t want anything getting hurt because of it.
https://linustechtips.com/topic/857893-my-first-build/#findComment-10681950
I would get it now, honestly. That's some pretty expensive hardware to run on a shit PSU. Have you already bought the case that comes with one?
Intel i7-7700k @ 5.1ghz | Asus ROG Maximus Hero IX | Asus ROG Poseidon Platinum 1080ti @ 2126mhz | 64gb Trident-Z DDR4 @ 3600mhz | Samsung 960 Pro 1tb @ 3500mbps/2500mbps | Crucial 240gb SSD | Toshiba 4tb 7200rpm HDD w/ Crucial 128gb SSD cache | Corsair Hx1000i PSU | EK 360mm Coolstream XE Radiator | EK-Supremacy Evo Waterblock | EK-DDC 3.2 PWM Elite Edition Pump | EK-RES X3 150 RGB Reservoir | Primochill AdvancedLRT Clear Tubing | Primochill VUE UV Blue Coolant | Corsair 570x Crystal RGB Case | 4x 30cm CableMod UV/RGB Widebeam Hybrid Led Strip | 3x 120mm Corsair SP120 RGB Fans | 3x Noctua NF-A14 iPPC 3000rpm Fans | 3x Noctua NF-A12x15 Fan | CableMod ModFlex PSU & SATA Cables | Asus ROG Swift 27" 4k IPS w/G-Sync & LG UD68 27" 4k IPS w/Freesync |
https://linustechtips.com/topic/857893-my-first-build/#findComment-10681960
I think you should go for the EVGA 450 B1, and the NZXT S340. You will get it cheaper and you will have a lot more space to build and it will look pretty clean :) . For the rest of your build it looks ok :D .
PSU : https://www.amazon.com/EVGA-BRONZE-Warranty-Tester-100-B1-0450-K1/dp/B01F5LX55K
Case : https://www.amazon.com/NZXT-Tower-Computer-White-CA-S340W-W1/dp/B00NGMIBXC
https://linustechtips.com/topic/857893-my-first-build/#findComment-10683830
The B1 is mediocre at best. The Corsair CX/M is available for less, and is better. The S340 is a completely different size from the Node 202, and OP prefers an SFF build.
https://linustechtips.com/topic/857893-my-first-build/#findComment-10683856
Case looks good, but I have to do more research on cases. The build keeps going up in price, with the node202, and if I want money left over for games a case swap is a good idea.
Thanks for the input.
https://linustechtips.com/topic/857893-my-first-build/#findComment-10685897
I’ll take a look at the PSU. If you have any suggestions for a cheaper SFF case let me know!
https://linustechtips.com/topic/857893-my-first-build/#findComment-10685903
The coolermaster v series is rated gold, is fully modular, and isn't much more than the CX PSU. I picked up a 550w for only 55 bucks yesterday.
https://linustechtips.com/topic/857893-my-first-build/#findComment-10685929
