[HELP] Home Media Player for my Parents
Solved by Aleks NE,
1 minute ago, titaniumshield said:So the components will just work fine with Remix Os I suppose. (except the DVD Writer, requires testing).
Is there anything that I can add or remove to make it more easy to use or maybe include some additional features to it?
I guess you can add a simple launcher from the app store to make it easier to use for them. But it's pretty simple as is, and it works out of the box for me.
