CPU cooler upgrade question
Go to solution Solved by iRileyx,
Noctua are one of the biggest companies when it comes to air cooling, so its safe to presume that they'll provide(rather, sell) mounting brackets for any new sockets if needed.
I also wouldn't push 1.45v let alone 1.5v or anything above, if you're having to push that high voltage you've lost the silicon lottery. It'll also lower the lifespan by quite a few years depending how often you run it at that voltage and not to mention at 1.5volts the temperatures will be stupid high, even with that Noctua cooler.
I current have a Xigmatek Dark Knight II CPU cooler and I'm capable of running my i5-6600k @4,7GHz 1,35v within 85°C while during a stress test with AIDA64 with every box checked. With Prime95 I get 100°C and some thermal throttling.
I tried 4,8GHz 1,40v but the system were unstable and while it run I got higher temps (100°C on AIDA64).
I'm want to upgrade to a Noctua NH-D15. I found tests showing temperatures 10°C lower on the Noctua NH-D14 than the Xigmatek Dark Knight Night Hawk, so I should expect similar results.
My questions are:
-I plan to replace my CPU in 2019/2020, what are the odds of the Noctua been compatible with the next socket? I know that nobody knows the exact answer, but what should a expect?
-If I was lucky with my CPU, maybe I can go to 4,8GHz 1,45V with the Noctua, but, giving sufficient cooling, can I go over 1,5V safely? if I can maitain my temps lower than 100°C, any voltage is safe?
Thanks a lot!
MoBo                           ASUS TUF GAMING X570 Plus/Br
CPU                             AMD Ryzen 5 3600x
CPU Cooler                 AMD Wraith Spire
Memory                       2x Corsair Vengeance LPX 8GB DDR4 3200MHz C16
SSD                             Samsung 850 EVO 500GB
SSD                             Kingston SSDNow V300 120GB
HDD                            Seagate Barracuda 3TB 7200RPM
Video Card                  EVGA nVidia GeForce RTX 2070 Super KO Gaming
Case                           Corsair Carbide 600Q
PSU                            Corsair CX750M
Optical Drive               ASUS DVD RW
OS                              Windows 10 Pro 64-bit
Keyboard                    Corsair K70 LUX Cherry MX Brown
Mouse                         Corsair Sabre RGB
Speakers                     JBL Peebles
Monitor                        LG 23MP55HQ 1080P 60Hz 5ms 23"
https://linustechtips.com/topic/856432-cpu-cooler-upgrade-question/
I would not recommend changing the cooler and spending that much (NH-D15 is not that cheap) to get a few MHz more.
I'd rather focus on changing the thermal paste to some better, improving the airflow inside the case and maybe even delid the CPU.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Pretty sure 1.4/1.5 volts is in LN2 territory. If you need to push the voltage that high, you lost the silicone lottery. Putting the voltage that high will also shorten the life of your CPU
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
I see, I will keep my OC as it stands then. Thanks for the input!
About the Noctua, I plan to also upgrade my case fans from the 2 included 140 fansto 2 Corsair ML140, but the upgrade to Noctua is intended to also be a life lasting upgrade that will handle every CPU I throw at it, make my CPU run on more confortable temps (now that improve OC is outo of question)
PSU                            Corsair CX750M
Using a great thermal paste compared to a good one gives a couple degrees lower temperature. For example, switching Arctic Cooling MX-4 with Cooler Master MasterGel Maker (nano) reduces temperatures on average by about 2°C.
Upgrading from a regular thermal paste to a great one might give about 10°C depending on the pastes compared. I've seen a bad paste (Spire Blue Frost) compared to a decent one (MX-4) give a thermal difference of about 15°C but that was in a laptop.
Replacing a "regular" fan of a CPU tower cooler with a fan with better pressure results also in a couple degrees lower temperatures. Going with a push-pull fan configuration on the cooler can decrease the temperatures even lower or might help keep the sound (noise) levels lower. Two 15dBA fans working together as push-pull might offer the same temperatures as a single 21 dBA fan but at much lower sound levels.
Delidding the CPU (and voiding the warranty) might decrease the temperatures for about ~10 degrees under load.
Going with a stronger cooler costs a lot. Fitting such a (huge) cooler into the case requires special care (the case should be wide enough) etc.
Consider all options. Sometimes cooling the VRM additionally (with a small fan) can also lower the CPU temperatures by 5-10 degrees.
Which thermal paste are you using? Have you tried using a better fan on the cooler you have? How about 1-2 additional case fans?
My thermal paste is the Xigmatek PTI-G3606 (https://www.overclockers.co.uk/xigmatek-pti-g3606-thermal-grease-3g-th-000-xg.html) it's not the best one, but looks like a inbetween good and great. Yes, my plan for 2018 is cooling upgrades, my case (Corsair 600q) came with 3 Corsair AF140, I'm planing on buying more 2 ML140, but I think I'll keep 4 fans total on my case, (2 in and 2 out) cause I can't think in a good wat to put 3 in and 2 out and I would like to use neutral to positive case pressure.
It's hard to add one more fan to the CPU cooler due to its shape, the way the fan mounts is by using some elastic band that you can see in the picture and there's not much space left fore another, but I may try to put my spare fan into it, will see. But it will be sketchy.
The 600q is a big case, so a larger heat sink will fit for sure.
About delidding I'm not sure. I want to do, but I've never done and I'm not planning to buy a new CPU the next year (nor could I afford it without a serious changing in my planing). And there's nowhere here that I know that does it, not near or that I can't trust. But I don't know, I want to do, but I'm afraid of messing things up.
PSU                            Corsair CX750M
