okay, so my laptop (specs in signature) is doing something really strange and annoying.
if it is unplugged, it throttles down all the way to 0.38 ghz, and stays there. if i plug it in, clock up to 3.08 ghz, and stays there.
how do i solve this? i can't use my laptop unplugged now.
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/855939-weird-processor-clock-speed-issue/
Check your power management settings. If you switch to the high performance power profile and everything acts normally, the issue is likely something that can be addressed by tweaking some of the advanced power settings.
i9-10900K, Asus ROG STRIX Z590-E Gaming WiFi, Asus TUF RTX3080, 32GB G.Skill 3200MHz CL14
Samsung 970 EVO Plus 1TB, EVGA Supernova 850W G3, Asus Xonar DGX
Fractal Design Define C TG, Noctua NH-U14S, Asus PG279Q 27" IPS 1440p 165Hz
i already checked everything. max cpu state is at 100%, cooling policy active.
i also tried setting every setting on the power slider in the taskbar, when i click on the battery icon.
She/Her
What does your battery's state of charge read when the laptop is unplugged? I've seen some devices immediately read 5% or less regardless of how long they had been charging and they did very odd things because of it.
it reads 99%.
it says 3 hours and 35 minutes remaining. on full brightness with the keyboard light on... so that's pretty normal.
also, this laptop is 2.5 months old...
She/Her
forgot to quote sorry.
She/Her
update: if i boot the system on battery, it stays at 3.08 ghz, and then after 2 minutes acts normally.
She/Her
