Hey everyone Ive found a solution for the one Lit and one unlit DIMM issue with the trident G-skill RGB Ram Modules
It turns out that all you have to do is uninstall the files properly
Ive attached .PDF instructions ive retrieved from the GSKILL site.
BP
TZRGB_BETA_cleanuninstallguide_easy.pdf
https://linustechtips.com/topic/855707-g-skill-trident-z-problem-solution/
