do you have z97
if you do:
bios
1.25v
4.1ghz
boot into windows, play some game, 30 minutes later:
reboot
bios
1.25v
4.2ghz
and so on, until it is unstable
once it is, bump the voltage from 1.25v to 1.26v, and so on
don't forget to run a CPU stresser for 2 minutes or so to get the MAX temp, if it is over 85c you need to stop.
edit: max safe voltage is around 1.35v or so, i wouldn't go beyond 1.365v or so for a stable overclock if there's a good stable one at 1.35 or 1.36v
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/855577-i5-4690k-overclock-help/#findComment-10654742
1 minute ago, themctipers said:
do you have z97
if you do:
bios
1.25v
4.1ghz
reboot
bios
1.25v
4.2ghz
Thanks for the advice, but I have a B85, not a z97
https://linustechtips.com/topic/855577-i5-4690k-overclock-help/#findComment-10654750
you cannot overclock, you need Z series to overclock.
https://linustechtips.com/topic/855577-i5-4690k-overclock-help/#findComment-10654751
the checking part, not how you open bios. I'm not that ignorent :)
Boot into bios by smashing DEL And see if you have overclocking tab
CPU: Intel Core i9 9900K | Ram: 32GB Corsair LPX 3200 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
https://linustechtips.com/topic/855577-i5-4690k-overclock-help/#findComment-10654799
3 minutes ago, cj09beira said:
you turn your pc off, start it again and press delete or f5 (during the boot it usually says press X to enter bios), then look for a setting called cpu core ratio
ok thanks
https://linustechtips.com/topic/855577-i5-4690k-overclock-help/#findComment-10654818
 I found this setting and it says auto, but I can change it. What should I do?
https://linustechtips.com/topic/855577-i5-4690k-overclock-help/#findComment-10654925
great, now the formula is: 100*"this setting"=clock speed, that 100 can also be changed no some boards but it affects most of the features of the board so its not easy to work with (not much benefit either)
so if you want 4.2ghz put in 42 etc,
follow the guide of the first guy that responded
https://linustechtips.com/topic/855577-i5-4690k-overclock-help/#findComment-10654938
All right. Thank you so much!
https://linustechtips.com/topic/855577-i5-4690k-overclock-help/#findComment-10655016
