Problems like the video but on my case wolfenstein 2 , cod mw2 , ac:origins , shadow of wars .
PC spes : win 10 x64 update / drivers update / ryzen 1600+b350+16gb+rx 580 +psu 750w plus bronce + ssd 120gb + hdd 2tb .
Rams are ok , hdds are ok , i change the psu for my old psu to test(evga 500w) , same issue , i move the games from hdd to the ssd , same problem , i change the monitor , the cables , and a test a few versions of amd drivers and nothing , the problem start 2 weeks ago when update windows 10 creator fall update + buy a new psu + install new amd videocard driver , i start to see again , on my old pc i see this problem too i5 2320 +8gb + 7970/960 , and never fixed .
https://linustechtips.com/topic/855347-lo-draw-distance-shadows/
that is a problem i do see in a couple of games i have, even with render distance maxed
gta v is 'known' for that, well at least for me.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
13 minutes ago, WereCat said:
I got the same "issue", it is the game, not your PC.
Witcher 3, GTA V, RotTR are all guilty of this as well as many other games. It is bothering me as well.
the videos its only for show the issue , on my case i dont have installed witcher , gta 5 , or rottr , only cod ww2 , wolfenstein 2 , shadow of war and ac origins, and shadow of war for example 2 weeks ago i dont have this issue , i am see videos on youtube of pc version(even with the same gpu) and the people dont have the same issue , even on max , the objects and shadow popping a few mts .
Look, my PC, same place in RotTR like on the video you posted, same issue...
yes but for example shadow of war the draw distance its not the same of 2 weeks ago , same the others game ac origins for example draw the shadows its really close , even on wolfenstein 2 or cod ww2 , i see videos with the same gpu , and nobody have this issues .
1 minute ago, MrTiC said:
Pretty much every console port from the past 5 years has this problem ...
Yes , but a few days ago i dont see this level of popping , the same story of shadow of war , now shadow of wars its really ugly like the shadows draw really really close (i use win10 version i can not use any program to make a video) ,later i can try with other driver , more old , but i try with 4 drivers :/ .
