Im from an other laptop atm and ive noticed sth strange.
When the laptop hasnt been used for 5-10 min it will blacken the screen to save power . Now usually when that happens all u need is to move the mouse or press some keys and it will re-open. This laptop on the other hand  does nothing! It's screen gets black  but i cannot open it again using the mouse or pressing the keys.
The only way opening it again is by pressing the power button again.
So can i do something to the settings so i can open the laptop by moving the mouse or pressing keys when it gets black?
https://linustechtips.com/topic/855178-laptop-settings-need-fix-pls-help/
  • 4 weeks later...
It's hibernating just change the power settings.
What operating system are you running?
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
