Hello LTT Forums, Lurker here.
I have a school assignment to collect some data through a survey, and I need a large sample size to take the survey (50+).
It's a quick and painless google docs survey (5 questions), and is completely anonymous. Complete it as many times as you want for various devices you own. Thank you!
https://goo.gl/forms/BiBEHi3hBAAbJLcN2
https://linustechtips.com/topic/855078-help-with-a-school-project/
BTW, with the question "How long does your battery last?"
Do you mean average usage, or how long if you use it all the time?
Because with average usage its much more than 14 hours....
Also, if many answers this, can you post the results?
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
I mean average battery life from day to day.
Edit: I'll post the results after it hits 50 surveys taken
Oh, then 14+ easy. I would have chosen 24 if thats an option.
BTW, I just noticed I could see the result with the press of a button when finished with an answer
-Stephen Hawking
