how do i boot plop through cd rom or usb directly? my machine does not support usb booting using plop i will be able to
but i burnt the plop iso to a disk and unplugged my hdd since it doesnt want to boot anyway :( so plugged in the usb and put the plop disk in the pc and set my boot to a cdrom b and still get boot disk failure if anyone can help id appreciate it my machine is old its from 2000
https://linustechtips.com/topic/854355-using-plop-to-boot-through-usbcd-help/
Damm, is that a Pentium 3 machine? Well, are you using a cd or a dvd? Sometimes, people screw up in that regard.
hey ive tried both dvd and cd disks still nothing
i plugged my hdd back in and im stuck on ''drives checking'' nothing seems to work and i think its celeron?! not sure tho
Well, I have had problems with CD's for a long while. I'm of no help, because it doesn't support USB.
