Error in code , please help
Go to solution Solved by WiiManic,
37 minutes ago, Aleksa Djordjic said:
Assets/Scripts/PlayerShoot.cs(53,31): error CS1503: Argument `#1′ cannot convert `float’ expression to type `int’
That means line 53, column 31 is where the error is.
If you look in your code there, you can see there is "_player.RpcTakeDamage(_damage);".
Argument 1 means the first thing you have passed to "_player.RpcTakeDamage", so "_damage" is the problem.
It can't convert it from a float to an int, so, "_damage" is a float, but it is supposed to be an int.
Once you change _damage to be an int, or _player.RpcTakeDamage to accept a float instead, that should work fine.
1 hour ago, Aleksa Djordjic said:
Original post is on another site but please answer here, there aren`t notifications on that site.
Original post:
http://forum.brackeys.com/thread/error-in-code-please-help/#reply_52869
it would have taken you seconds to copy the images over to here..
"cannot covert float to int" means exactly what it says somewhere your code is trying to convert a float (1.23) to an int (123).
without bothering to post your code then that's all the help anyone can provide
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
Sorry
I did convert it to int and now there is another error :
And i dont know what it means by Argument `#1`
CPU: 6700k GPU: Zotac RTX 2070 S RAM: 16GB 3200MHz  SSD: 2x1TB M.2  Case: DAN Case A4
Ok , tnx :)
I will try this tomorrow (i am in Europe so time is different for me) because it is late now and i have shutdown my PC.
Also thank you for explaining to me what 53,31. I tough that it means that problem goes form 53rd line to 31st line xD
