So, I helped my friend build his computer. It has the following specs:
Intel Core i7 4770K
16GB Corsair Vengeance Pro 1600 Gold
ASUS Z87-PRO
Corsair H80i
Corsair 750D
2TB WD Black
EVGA GTX 770 2GB Superclocked
Corsair HX 850
and when he turns it on, it hangs with no screen output and the error code A2. We have tried pressing the MemOK button, swapping RAM DIMMS and trying integrated graphics. And yet, the same result. What next then?
https://linustechtips.com/topic/85332-asus-z87-pro-issues/
Intel Core i7 4770K
ASUS Z87-PRO
Corsair H80i
Corsair 750D
2TB WD Black
Corsair HX 850
When it comes to pcs this is my area of minimal expertise, so my advice is as follows;
Option 1: Look up on google possible causes of this error, and see if any other people with this motherboard experience the problem, and what solution they had.
Option 2: Contact customer support for the company
Option 3: Cry.
(I have no fuckin idea how to fix bios problems, never had one.)
Edited by Luclocke
Heaven's Society - Like Anime? Check us Out Here!
https://linustechtips.com/topic/85332-asus-z87-pro-issues/#findComment-1160235
Option 3: Cry.
1. Already did, can't find anything definite.
2. 4:04 AM, not sure if they are around.
3. I want to.
https://linustechtips.com/topic/85332-asus-z87-pro-issues/#findComment-1160246
3. I want to.
1. Do it again.
2. Worth a shot.
3. I'll hold you baby <3.
4. While you're waiting for number 2, do number 3. :) Multi-tasking!
https://linustechtips.com/topic/85332-asus-z87-pro-issues/#findComment-1160250
You sure it says A2? I'm looking through my Pro's manual and there's no A2 in the list of codes.
https://linustechtips.com/topic/85332-asus-z87-pro-issues/#findComment-1160274
Have you tried removing the gpu and running off of the igpu?
We are about to try this.
I am sure it says A2.
https://linustechtips.com/topic/85332-asus-z87-pro-issues/#findComment-1160278
Damn I failed there. Dunno how I missed that. I'm tired.
https://linustechtips.com/topic/85332-asus-z87-pro-issues/#findComment-1160284
Me too. 4:20 AM on my weekend to try and fix this doesn't work for me. I want to just sleep, eat, Teamspeak and Litecoin mine.
https://linustechtips.com/topic/85332-asus-z87-pro-issues/#findComment-1160290
Since you're using an ASUS mb, it should support BIOS flashback so try that (http://www.asus.com/Motherboards/Z87PRO/#support
I'm about 80% sure it's a BIOS issue
i5 4670K | ASUS Z87 Gryphon | EVGA GTX 780 Classified | Kingston HyperX black 16GB |  Kingston HyperX 3K 120GB SSD | Seagate Barracude 3TB - RAID 1 | Silverstone Strider Plus 750W 80Plus Silver | CoolerMaster Hyper 212X | Fractal Design Define Mini
https://linustechtips.com/topic/85332-asus-z87-pro-issues/#findComment-1161268
Okay. I will have him try it when he gets in touch with me.
https://linustechtips.com/topic/85332-asus-z87-pro-issues/#findComment-1161426
I legit tried everything that I could. switched up the ram sticks one ram in every slot one by one  tried no Hdd or dvd. tried with no gpu idk whats wrong im so stressed this is my frist build ever im confident I put everything in the right place and all.
Does the same error code show up if there is nothing on the motherboard but the cpu & its cooler. I.E. no gpu, no drives, no usb devices, no memory, no case fans, no monitor, no keyboard, and no mouse?
If so, it's either cpu or motherboard.
If not the error code should be for some missing item, like memory error. So add that component back on the motherboard. If it's memory, just put one stick in for now. Power up and check the error code. Repeat.
https://linustechtips.com/topic/85332-asus-z87-pro-issues/#findComment-1164104
